- Sep 23, 2001
- In your head (Ottawa.Canada)
Read the whole thing before jumping in w/ the obvious answers, there is a face palm at the end.
Since I work mainly from home these days, I need a good connection for all those zoom calls. I noticed my speeds were not as advertised, zoom calls drop from my end and wifi would cut out a lot. I increased my Internet speed from 10MB/s to 15MB/s ($2 increase so why not) and still only getting 9MB/s as slow as 3MB/s. Ugghhh....do I need to get a new router, maybe try a mesh set up? I asked my friend about his Mesh set up...something triggered me in his answer, and not in a SJW kinda way. He said he uses cat6 cables. As my router is very far from the office, I use a wifi extender and run a cat 5 cable from it to my pc. I did a little research and learned that Cat 5 has speed limits. So I checked my router/modem to see what the cable connecting the two was, sure enough. An old cat 5. I rummaged thru my tickle trunk and found:
I bought 5 cat 6 cables and redid all my connections.
I saved myself a few hundred dollars as I was about to go w/ a Mesh set up....and if I did, I likely would have used the same o cat 5 cables and kept the new cables in their respective packaging, as ive done for years. all the new tech that I got, router and Modem, I keep the cables in the box, pfffft.....ill use whats already connected, for the past 15 years!!!!!
The wifi has been stable and constant speed w/ no drops to 3MB/s. Rookie mistake !
- a cat 5 e
