- Apr 1, 2010
- Wakefield, QC
So... I bought this RAM: Vengeance Pro 1866Mhz 2x4GB 9-10-9-27
I was expecting to achieve 1866Mhz at rated timings on my AMD Athlon II X4 635. Seems like it won't be that easy.
Now the said CPU natively supports up to 1333Mhz RAM, but with my previous set of RAM I could achieve almost 1600Mhz without touching any voltages (234Mhz "FSB" on 1:3.33 mem ratio). By using a low RAM ratio I can easily OC this CPU to 3.4Ghz (234Mhz x 14.5 multi). But if I try with the 1:4 ratio I just can't go past 210Mhz on the "FSB", resulting in RAM speeds of 840Mhz (1680Mhz effective), and a pathetic CPU OC of 3045Mhz. I was totally hoping for my 3.4Ghz OC and 1866Mhz RAM on this setup.
My best guess is this is caused by the IMC in the Athlon II... right? If so, is there any chance I can have my RAM at its rated speed and timings with this CPU?
By the way, mobo is MSI NF980-G65
Any help would be greatly appreciated!
