Hi, I have small issue with my OC.
My system:
Gigabyte X38-DQ6
Intel Core 2 Duo E6750 (default @ 2.66GHz)
2x 2GB OCZ Platinum Edition 800MhZ
Antec P185 with plenty of fans and ideal airflow (al cables hidden...)
After some research I found that I should be easily able to set my CPU clock to 400x8 (-> 3.52GHz) instead of the default 333x8 without needing to tinker with any voltages, RAM timings etc...
So I set that option in my BIOS and never have any stability or temperature issues.
Now once in a while my pc just boots with the OC setting disabled. The 400x8 setting is still visible in the BIOS, just not enabled...
Every time I try to switch the OC back on the pc boots as if I set it to an impossible setting. At POST, instead of reading the CPU details, 'counting' the RAM and moving on to the HDD's it just shows the default CPU speed and then 'MEMORY TE' (instead of 'MEMORY TESTING' and the amount of RAM) and then reboots and szitches back to default.
Even setting the OC to 334x8 does not work.
Now after a couple of days I'm able again to set the OC to 400x8 or even 440x8 and my system still remains stable until one (re)boot when the setting is gone again.
It sometimes happens after days, sometimes months,... and I can't really find the cause. It's not like it happens every time I stress my system, it seems completely arbitrary...
Anyone have any ideas what causes this?
Thank already for the help!
My system:
Gigabyte X38-DQ6
