To Frakk, you mentioned using window8 for the benchmarks, why not use a Linus OS for the benchmarks? for me I'd be using Piledriver cpu for Linux and my whole new build will be around Linux. Linux is starting to make way in the OS, and to me the AMD Asus Mobo compete (Linux VS Windows specific Mobo's), why would you get a AMD Asus Mobo and not have it for Linux? Is it not true that AMD Asus Mobo are for OS systems other than windows? Would the benchmarks be different with Linux vs Windows?
I do have Ubuntu, AMD + Asus + Linux is like hand in Cat Skin Glove.
I'm not at all surprised AMD are working with the Open Source community, or that 'they' seem to be jumping at that chance to work with AMD.
All the good about Open Source software can hardly be over stated , and there is some very good stuff out there challenging every commercial equivalent, often much better.
But for me the sad reality is its Linux based OS where it all starts to come unstuck.
They seem to be in conflict with them selves, on the one side you have those who reminisce over the pre Windows / Apple times, where doing the simplest of tasks requires hours of hand typed commands and codes.
On the other side you have those who want Linux based OS like Ununtu to be a viable replacement to commercial OS like Windows.
The end result is half the time Ubuntu works just like windows, IE install the software and go, no hassle and it just works, but then you want to do this or that and you need 6 different programs, some of them need extensive codding knowledge, others need command line operations and then you have to compile all that together, if your lucky it worked, if not you have just waisted 3 hours of your life and gained a head ache.
For that reason its limited to the amount of people who can use it and do without Windows. IMHO until they fully commit to being a replacement to Windows it never will be.
Ask yourself why so much of Open Sours software is available for Windows when not long ago most of it would only run on Linux.
As for benchmarking my CPU on Linux? well you and i know what the results mean. the trouble is there irrelevant and meaningless to the vast majority as they only know performance on windows with windows apps.
