- Oct 5, 2012
- Quebec, Canada
- Thread Starter
- #21
Alright, starting up reformat & OC. Will be back later!
2x2gb @ 1333, Yep.
I think 60°C would be way too high, 50°C would be a "do something to lower that temp" limit, as far as I know AMD don't like 45°C+.
Once installed, I'll check the stock stats from the BIOS, note them, and check with HWMonitor, run a Prime95 and printscreen, and post.
The files are still there, the program found them. I just need to find a way to access them.
I took this hard drive from an ACER, I wanted those 320Gb.
At first, it was splitted into 2 partitions (or so I thought) of 144Gb. I decided to use it as a secondary drive, my main being 80gb.
Then I found out about the ~10gb recovery partition.
