- Aug 1, 2006
Hi there. I'm trying to determine what kind of upgrading options I have now. I recently upgraded the video card to evga 7900GS and just added 2 x 1GB OCZ Platinum yesterday.
Just to clarify, I'm not looking at upgrading to AM2, at least right now. I'm going to stick with the 939 a little longer as it's working fine, but I just want to squeeze as much performance out of it as I can.
What do you think my bottleneck is?
My thoughts were either the mb or the hdd.
The mb: http://support.gateway.com/s/MOTHERBD/FIC/4006111R/4006111Rnv.shtml (Foxconn)
Unfortunately, the case/mb are a proprietary uBTX form factor, so if I have to upgrade those, I'm just gonna get AM2 probably. The BIOS is also their modified version of Award (I think) and there aren't even any visible options for voltage, multiplier or any OC'ing tweaks.
The hdd, from what I can tell is a pretty standard 250GB Western Digital 7200rpm 8mb cache.... I've been looking into getting a Raptor, but not sure my mb would support it -- any thoughts? I've also considered getting another drive and setting up a RAID0 or RAID5 array. I've never done that before, so it would take a little reading to get on the right track.
I also can't change the voltage or timing on my OCZ RAM (thanks to Gateway BIOS), although I hear it OC's quite well. I ran Memtest86+ for a few hours and it did just fine. No errors and timing was 2.5-3-2-5.
I'm also looking into components that can be carried over to an AM2 board when I decide to upgrade --- like the 7900GS and Audigy 4 that I already have...obviously the cpu, RAM and mb won't be able to though...
-Ryan
-Ryan
