Bakercake Member Joined Jul 22, 2010 Oct 7, 2010 #21 Try setting your ram timing to 9-9-9-25-40-2T and the voltage to 1.600v. Change your fsb back to 200.
OP N8N8N8 Member Joined Feb 11, 2010 Location PA Oct 7, 2010 Thread Starter #22 I minimum I can change my ram to is 1.5v - 1.65v. Isn't 1.65 going to be high?
Bakercake Member Joined Jul 22, 2010 Oct 7, 2010 #23 N8N8N8 said: I minimum I can change my ram to is 1.5v - 1.65v. Isn't 1.65 going to be high? Click to expand... Look for the default voltage on the ram. The package should say it(If you still have it) or google the ram you have.
OP N8N8N8 Member Joined Feb 11, 2010 Location PA Oct 7, 2010 Thread Starter #24 ya it's 1.5v default should I still change the timings but keep the default voltage?
Bakercake Member Joined Jul 22, 2010 Oct 7, 2010 #25 N8N8N8 said: ya it's 1.5v default should I still change the timings but keep the default voltage? Click to expand... Yes, but I would try 1.6 if your problem still exist.
