For all of you who go from an old bios to a new one like A9 you should be aware of this:
Why is my idle temperature so much higher under BIOS version 3R or later?
With previous BIOS versions ABIT set a bit in the BIOS CMOS (offset 52 bit
7) to "1" to enable the ACPI "HALT" function and cool down the CPU temp in
idle mode. This, whilst allowing cooler CPU operation, is against the
advice of AMD and VIA. Under earlier AMD processors, however, this
modification allowed the system to idle cooler and had no ill effects.
However, it was been found with newer 133MHz FSB processors running at
1333MHz and higher, that this software cooling can cause severe stability
problems - especially under Windows 2000. As a consequence, in all ABIT
BIOS releases after version 3R, ABIT have set this bit to "0" - the value
recommended by AMD and VIA. This allows the motherboard to be stable with
all AMD processors at the expense of an increase of 5-10 degrees
Centigrade during idle (from approximately 35 degs C to 45 degs C). This
will not harm your motherboard or processor. Note that this CMOS setting
is widely used by other KT133/KT133A based motherboards. Note that if
your processor is slower than 1333MHz then you can revert to the previous
setting of the BIOS by using H-Oda's WCPREDIT and WCPRSET programs to
modify this register value. If you are using Hex mode in these programs
then change register 52 from 6B to EB to re-enable the software cooling.
See downloads page for programs
