- Jun 23, 2004
- HELL, were else?
daniel_dynasty said:aww too bad i have a p4 socket 478!!!!!
Yes, 3 min. it was a joke. But also...You should post your rig in your sig so people know what your comp is. k?
JFettig said:has thermaltake ever done anything becides the orb origional? actually I dont think the orb was even origional. some panasonic hs was like that probably before it.......
I wouldnt support their habits, thermalright is the way to go
Jon
nocturnal714 said:well i just installed my sp97 and i'd like to say...this is the best hs out there. my load temps have dropped dramatically. i'm nowhere above 40 load and i'm running 230x11.5 with 1.8 vcore and i'm about to move up. the only issue i have with thermalright though is the installation procedure. i had an annoying time trying to install this thing because i have been using clip ons for a long time for their ease of taking off the hs. if i get the settings i want i will not take this hs off again as it was very annoying to install and i don't think i can go through it again.
nocturnal714 said:yea i've been practicing putting it on and off today and i think i finally got the hang of it. problem wuz that i machine screwed the bolts on when the directions say to finger screw them tight. that was a big mistake.
Hellion said:ARHAHAHA! LMAO practicing puttining it on and off.
Its cool, guys dont read instructions anyways right? heh i do....NOW!
