- Aug 18, 2010
- Dallas/Fort-Worth
Rock on...
Rock on...
That is the down side to GPU folding...lots of heat and not as efficient as the CPU folders.
As ChasR says, SMP is more efficient, but that's with the current client. v7 may bring changes to this, however.
No you don't need another monitor.
I'm assuming Windows 7
I'm assuming you reinstalled the drivers after you installed the 9800
First create a directory named FAH anywhere except Program Files or Program Files (x86).
Next Create a directory under FAH named GPU 2
Download the 6.23 GPU2 Console Client from here into the GPU 2 directory.
Extract the files into the GPU 2 directory.
Right Click on the executable and create a shortcut.
Add -configonly after the last " in the target box: ...xe" -configonly. Space between " and -
double click on the shortcut which will start the configuration process.
Add the usual user name team number, passkey if you have one, say yes to change advanced options. Change core priority to low, memory to 500 MB, Machine ID to 3 (it has to be different from the other clients), No to a service (for now), yes to disable affinity lock, Use the default on all other items down to extra parameters. There add -gpu 1 -verbosity 9 -forcegpu nvidia_g80 and hit return until the client closes.
On your systray client you will need to add -gpu 0 -verbosity 9 and to be safe in a mixed environment, -forcegpu nvidia_fermi into the extra parameters box of the configuration
Now right click on the FAH executable in the GPU 2 directory and send to desktop (create shortcut). Start the client with the shortcut. You may wish to copy the shortcut to the startup directory so FAH starts with windows.
No problem. I'll be waiting for you to pass me.
Fans. Lots of fans. Oh yus!
