- Mar 3, 2004
Time to OC this 3.0C -- Info Needed!
Ok so I'm all set to give my 3.0C the work out. I am about to start upping the FSB till it wont post.
But I need to get a few things straight.
CPU Voltage. I understand it would help to up this a step when I top out at my max FSB. What is the stock voltage? My BIOS allows for 1.3v - 1.6v in .5v steps. I seem to see voltages much higher than these in some peoples signatures.
DDR Voltage. Same as the CPU up it one notch when it tops out. What is stock? BIOS allows for 2.7v 2.8v 2.9v.
Im almost sure you are going to say that my mobo isn't going to let my voltages go up as high as it should. SO..
-System Specs-
P4 3.0 HT 800FSB
SP-94 and AS5 w/ 92mm Panaflo
Soyo Dragon 2 Platinum
ATI Radeon 9500pro
There is a BIOS update for my mobo ...
http://soyousa.com/downloads/select...oc_Intel+Pentium+4&col2=233&col3=BIOS+Upgrade
The one at the bottom says overclocked BIOS. God I'd hate to flash my BIOS.. but if its neccasary... lets see what I can't get up to without doing that. (I dont even have a floppy drive installed on my computer lol).
So anyway.. I FOLD so it has to be 100% stable 24/7.
Running at 3.22GHZ at the moment.. I want to get this all straight before I go for bigger...
FreakinSyco
(PS I have no idea what batch .. or numbers.. are on my processor.. I shoulda looked yesterday when I put on the SP-94
-System Specs-
P4 3.0 HT 800FSB
ATI Radeon 9500pro
FreakinSyco
