Yeah man I hear you. If you add 20C like some people are saying then I hit 65C (45C displayed on OHM/CPUID/whatever) before things start to get silly. I won't rule out that the temp sensor is way the hell off on these chips, but that's all I have to go on, and I can play Skyrim for endless hours logging a near-constant 45C. I've had readings up to 50C (very warm room), in case anyone thinks the sensor maxes out and just doesn't read higher than 45. Does anyone really know what kind of correction to apply here to get an "actual" core temp?
Based on the tests of this HSF at FrostyTech, I'm gonna say the temps it's reading are accurate, or damn close. Stock clocks the chip is 100W TDP, and under load is right in line with their measurements. Overclocking to 2400 RAM/1100 GPU with the necessary voltage increases that to maybe 130W, at the most, and there's a corresponding rise in temperature. I've little reason to doubt this chip is running as cool as it says. I guess people are just afraid of voltage. Can't blame them.
BTW edited my previous post, any advice on what MB I should select here?
