Brittanica said:
hydrolysis, in chemistry and physiology, a double decomposition reaction with water as one of the reactants.
You can hydrolyze Ozone, but you can't make it via hydrolysis as far as I can tell.
I think you're thinking of Electrolysis, the breaking down of water with electricity. Not something we do in computers much.
Ozone can also be produced by electrical equipment that uses high voltages, such as photocopiers and laser printers. Not, however, internal computer bits. The highest voltage you'll find in a PSU is 380v, and its pretty well separated. 380v and that much separation is unlikely to produce much via corona discharge.
Ozone is produced by arcs, regardless of voltage. Hence anything with a brushed motor create some. Computers do not use brushed motors.
UV can create it, but computers don't use UV.
How about a link? You're the one trying to prove something here
Would you listen to someone who said "This is how it is. I'm not going to show you how I know because I already know"?
Water system water is under considerable pressure, which dissolves more gas into it than would normally be in it. When you take the pressure off it by putting it into an open container those gasses come out. They're primarily nitrogen, oxygen, and co2.
Totally normal, most tap water will do it.
The effect is even large if you heat the water suddenly, as hot water can hold less dissolved gas than cold water.
