Hello Everybody,
Below is the info on my HP xt934 Pavilion pc. I want to o/c it, my budget for extra hardware/cooling is $150 -
CPU Properties
CPU Type AMD Duron, 900 MHz (4.5 x 200)
CPU Alias Spitfire, Athlon Lite
CPU Stepping A2
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 64 KB (On-Die, Full-Speed)
Core Voltage 1.6 V
I/O Voltage 1.6 V
Typical Power 24.5 - 37.2 W (depending on clock speed)
Maximum Power 27.4 - 41.5 W (depending on clock speed)
CPU Utilization
CPU #1 0 %
Motherboard Properties
Motherboard ID <DMI>
Motherboard Name Asus A7V-VM
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 100 MHz (DDR)
Effective Clock 200 MHz
Bandwidth 1600 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Chipset Bus Properties
Bus Type PCI
Bus Width 32-bit
Real Clock 33 MHz
Effective Clock 33 MHz
Bandwidth 133 MB/s
Physical Memory
Total 503 MB
Used 174 MB
Free 328 MB
Utilization 35 %
Swap Space
Total 1230 MB
Used 136 MB
Free 1094 MB
Utilization 11 %
Virtual Memory
Total 1734 MB
Used 310 MB
Free 1423 MB
Utilization 18 %
Memory Module Properties
Serial Number None
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Normal (15.625 us), Self-Refresh
Highest CAS Latency 3.0 (7.5 ns @ 133 MHz)
2nd Highest CAS Latency 2.0 (10.0 ns @ 100 MHz)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Supported
Precharge All Supported
Write1/Read Burst Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Chipset Properties
Motherboard Chipset VIA VT8364(A) Apollo KL133(A) / VT8365(A) ProSavage KM133(A)
In-Order Queue Depth 4
CAS Latency 2T
RAS To CAS Delay 2T
RAS Precharge 2T
Integrated Graphics Controller
Graphics Controller Type S3 ProSavage
Graphics Controller Status Enabled
Graphics Frame Buffer Size 8 MB
Memory Slots
DRAM Slot #1 256 MB (SDRAM)
DRAM Slot #2 256 MB (SDRAM)
AGP Properties
AGP Version 2.00
AGP Status Enabled
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x
Current AGP Speed 2x
Fast-Write Not Supported
Side Band Addressing Supported, Disabled
Chipset Manufacturer
Company Name VIA Technologies, Inc.
I tried to post as much useful info as possible, I've read many of the articles in "Beginners Guide" and "Tips and Techniques". I've learned a whole lot. I'm very comfortable with tinkering with my pc, I upg'd to 512 mb a month ago thanks to the articles on o/cs.com.
Your help is greatly appreciated,
Beginner
CPU Properties
CPU Stepping A2
L1 Code Cache 64 KB
L1 Data Cache 64 KB
Core Voltage 1.6 V
I/O Voltage 1.6 V
CPU Utilization
CPU #1 0 %
Bus Width 64-bit
Bandwidth 1600 MB/s
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
Bus Type PCI
Bus Width 32-bit
Real Clock 33 MHz
Bandwidth 133 MB/s
Physical Memory
Total 503 MB
Used 174 MB
Free 328 MB
Utilization 35 %
Swap Space
Total 1230 MB
Used 136 MB
Free 1094 MB
Utilization 11 %
Virtual Memory
Total 1734 MB
Used 310 MB
Free 1423 MB
Utilization 18 %
Serial Number None
Memory Type SDRAM
Module Width 64 bit
Chipset Properties
CAS Latency 2T
RAS To CAS Delay 2T
RAS Precharge 2T
Memory Slots
AGP Properties
AGP Version 2.00
AGP Status Enabled
Beginner
