Your heatsink and fan setup are INSANE
I have to do this setup. I'll be peicing everything together for the HHC-001 next week. I'm calling Fry's tomorrow for the 60 to 80 adapter and the 80 Tornado fan.
CompuWolf if I use a this 80mm fan. Will it drain my psu? I heard HP psu's are horrible? I found a place call EZ Supply that sells refurbished equipment. Some of the refurbished psu's I saw were under $20. Is there a model your recommend?
My pc current has -
BST ATX-1523D D2
I googled and found the above
Bestec ATX-1523D Power Supply 150 Watt Power Supply
I was wondering if I could upg'd to one of these?
Bestec ATX-250-12E Power Supply 250 Watt Power Supply New 40
Bestec ATX-250-12Z Power Supply 250 Watt Power Supply
Or these -
HP 5187-1098-SUB Power Supply 250 Watt Power Supply
HP 0950-3971 Power Supply 250 Watt Power Supply 11 Connection
HP 5187-1099 Power Supply 250 Watt Power Supply
HP 0950-3949 Power Supply 250 Watt Power Supply
Since I have a 150W a 250W should be ok.
I found these at this link -
http://www.pctogo.com/dbapplet/html.html
Is it possible that I can use a retail psu? I seen one at fry's 350w for $19.99?
Thank you
