g0dM@n said:Rat, how did you find out mobo revision (also which is best)?
Also, did the J17 mod help out your OC more? I was thinking of doing it as well, but not if it doesn't make a difference.
Jimbob7 said:https://www.komplett.co.uk/k/ki.asp?sku=308282 - is where i got them
g0dM@n said:H rat, I know what the mod is. I was asking if it has a REAL advantage over the regular 5v jumper trick. I do have an adjustable PSU, and all... I know exactly how to do the mod. I was asking if it actually helped you to perform better, and YES I know that you can adjust it completely to any value you want from 3.3v+... I could go up to like 3.8v on my PSU before hitting the trip voltage.
I could NEVER figure out what "us" my ram is... and what the procedure is to find out the correct cycle time. If you know the formula please state it, but also tell me how I find out the "us" thingy for my ram (I don't even know what that stands for). I have TwinMOS SP BH5 (according to this thread).
Sharp, http://www.dfi-street.com/forum/showthread.php?t=10411
The unit, it is measured in clock cycles.
eg
1560 clock cycles.
That indicates it is related to frequency as 1 clock cycle on a 200Mhz frequency is 5 nano-seconds.
So 1560 clock cycles = 1560 x 0.000000005 = 0.0000078
that is 7.8uS (Micro-seconds).
So 1560 cycles = 7.8uS @200Mhz.
At 260Mhz, 0016 cycles = 0.062uS
What is the default Refresh rate of your modules?
Use everest home edition and look at the SPD info.
That is my view on this settings in the BIOS.
Your ram spec should say a refresh interval time, eg 7.8uS or 15.6uS.
The refresh intervel is how often the memory cells on the modules are sent a pulse of electricity, this lets it maintain its charge.
Now,
200Mhz = 5nano-seconds
250Mhz = 4nano-seconds
300Mhz = 3.3nano-seconds
How does one work this out?
Using the formula 1 / f = t,
1 / 200Mhz = t
Remeber that Mhz =1,000,000
so
1 / 200,000,000 = 0.000000005 (that is 5nano-seconds)
But to make things easier just use 1/200 then multiply the answer by 1000.
1 / 200 = 0.005
0.005 x 1000 = 5ns
Do that for any frequency and you will be able to calculate the time in nano-seconds.
The second part was 1560 clock cycles < these are the options in the BIOS.
So to work out the Refresh interval you just multiply this value with the nano-seconds you just worked out.
If you ran your modules at 200Mhz the time in nano seconds would be 5ns
Now 1560 x 5ns =7800 but as 1 nano second = 0.000000001 seconds.
your answer is 7.8uS (micro-seconds).
But the bit that needs testing, if you overclock the modules should you try and maintain the default refresh interval?
So if the the spec for your modules said 7.8us and you run the memory at 300Mhz what tREF value should you use?
If you understand what was said above then it should be
t x clock cycles = Refresh rate
I have shown you how to work out t
The modules spec states the Refresh rate, eg 7.8uS
With 2 knowns you should be able to work out what value to choose in the BIOS
Remember how to rearrange a formula?
you should end up with:
Clock cycles = Refresh rate / t
So,
assuming the spec stated 7.8micro-seconds
Clock cycles = 7.8 / (1/300)
= 2340
Then check for the closest value in the BIOS.
Notice that you dont need to multiply anything by 1000.
So the final formula would be
Clock cycles = t / (1/f)
f = the frequency.
Eveything I have said is just a theory which does need testing
Jimbo Mahoney
From my understanding, if the Tref is too high, the memory isn't getting refreshed enough and risks losing data. If the Tref is too low, it's getting refreshed too often, causing instability due to power / heat issues.
