- Jan 1, 2008
- Colorado Springs, CO
JCE3000GT, I don't feel the Fx 4xxx should be in the conversation, mainly due to the slight price difference between the Fx 43xx and the Fx 63xx chip. DNRDustin, does make a good point in most cases a Fx 63xx chip will do everything you need for gaming as a Fx 83xx chip. I have both the Fx 6300 and Fx 8350 and while gaming for example BF4 I do not see or feel any difference when playing on either. Unless a game can take advantage of all the "cores" of the Fx 83xx you most likely will not see much difference between the two. That said every Fx 63xx I've seen come through this forum will need slightly more voltage for the same Oc as a Fx 83xx. It may be, as Caddi stated, because they are just Fx chips that failed as 8 cores. Most of the time, you can Oc a Fx 63xx slightly higher on X cooling then a Fx 83xx.
Unless one is utilizing a program that will run on all 8 "cores" such as rendering videos or doing some mathematical computations you likely will not see much difference between a Fx 63xx and a Fx 83xx chip.
Don't forget dev work + virtual machines
I can do some serious core consumption contributing to open source projects such as SWGEMU where you have to compile and test changes made to the source code serverside software then run it in a VM to test its functionality
