- Thread Starter
- #61
it will not bottleneck your card.
the 4 cores are failed 6 cores so you might find that the 6300 will clock better than a 4350 with less vcore and run cooler at the same clock speed.
Just to make sure I understand...
If I OC the 6300 to match the 4350's clock speed it will run cooler and use less volts? I will assume my H80 cooler is still viable for this..?
