- Jul 30, 2014
Motherboard/CPU/Ram in sig.
No clean install, was a HDD swap, used paragon to get the machine bootable. Once I did that removed every driver not in use from device manager rebooted then installed all the B450 stuff. Now just sitting on those two devices but none of the drivers that came with the B450 are compat. Tried to driver search aswell online but no luck.
do those front ports have a header from the front panel you didn't plug in?USB 2.0 ones x 2
A simple typo. Nkt = not.Whats an nkt issue?
I asked earlier, is device manager showing anything?
I still say clean install...make sure your motherboard is using the latest bios, etc. The basics.
Time-Bandit, I had a very similar experience with a customer's computer in the past year. She had programs on the old machine she didn't any longer have installation media or download keys for and didn't want to lose them. So I built her a new box, also Intel but the components were like 12 years newer. I just used the existing drive from the old machine since it was a fairly new SSD. Booted into Windows fine, installed new drivers and I thought everything was good to go. But over the next week or so the system began to unravel and the USB ports became dysfunctional. Had to wind up doing a clean install after all in order to fix the issues.
