- Nov 30, 2003
Hi all,
Not entirely sure how active this forum still is after all these years but I need some help.
I've had my 8700k/Asus HeroX system for 2 years and never had any issues but in the last week or so I've been getting constant BSODs, kernal error, memory management, iqrl error, among others.
Thought initially it was a dodgy driver so reinstalled all the drivers on my system and that didn't make any difference so tried a fresh install of Windows10, still no cure. Checked device manager and found that "hid compliant headset not working" was being reported so uninstalled the driver and kept my usb headset unplugged, still get BSOD.
So with the memory management BSOD I thought maybe it's one of my RAM sticks are dying (G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14D-32GTZR) so I tested them individually in Memtest86 for four passes, no errors. Tested them together in slots 2 and 4, no errors. Tests done with and without XMP.
The PSU is not too old, maybe been using it for 10-12 months. Corsair HX1000i.
Graphics card is a 1080Ti (It has been overclocked since day 1, no heat issues, usually sits around 70-75c under maximum load) that I've had since launch so it's getting on a bit but I don't think this would cause the BSOD that I am getting?
Windows10 is installed on a Samsung 970Pro NVME m.2 drive that seems to be working correctly.
The BSODS seem to occur at random times, sometimes not for 30 minutes and sometimes I can't even download 200mb drivers without it crashing three times.
Doesn't seem to be heat related, 8700k under load is around 60-70c (Kraken X62), the overclock I've had it one for the last two years was 5.0ghz but with only 1.28vcore, I always left the memory timings alone and just used XMP defaults.
I'm thinking that possibly I've got a faulty motherboard, but wouldn't memtest86 show that?
Is there anything else you can think of?
My keyboard and mouse is a USB Coolermaster one, I forget the name, peripherals I used are Logitech/Saitek X56 Hotas, TrackIR5 sensor and software, HyperXCloud USB headset with mic.
Nothing is new, it was all working perfectly fine up until about a week ago.
Any advice or help would be much appreciated.
