- Sep 14, 2006
- Lahaina, Maui
OK so I have an ASUS P6T Deluxe v2 with a 920 i7 running stock cus of what is going on. I've had this box for years and have only upgraded the gpu, ssd, memory to 12gb.
I used to have a direct connection to the router, but recently moved and need to setup a wireless connection..I have a wireless pci card that works (I'm using it now) but its in-between my x-fire setup as its the only slot available. My x-fire is blocking the last pci port So off to the store to buy a usb network adapter.
Problem: Wireless USB adapter is detected and installed in device manager, but is disabled and won't enable. Power is there, you can see the light on, but not working and cannot enable thru device manager or network/sharing even after complete uninstall/reinstall and disabling/enabling.
Running Win7 Ultimate 64bit.
Yes I have all drivers up to date.
Tried 2 different adapters so It's def my computer. Not sure if its windows or bios issue? 1st one NetGear Wirless N 600 v2, 2nd one is a Cisco/Linksys AE3000. Both worked on my room mates laptop running win7 32 bit. Both did not work on my computer but were detected and appeared installed however could not ever enable them and would hang during installation detection phase.
What I've tried for solutions:
netsh winsock reset
checking the wlan services and making sure its set to automatic
updating drivers/chipset of my mobo (also tried the previous version to be sure this wasn't the culprit)
Uninstalling/reinstalling on multiple usb ports all doing the same thing
I dunno what else to try. I've tried everything. There is something stopping the wireless adapters from being enabled within windows. Is it possible its a BIOS issue? I'll try updating that next, but the current BIOS only gives me the option to turn on/off the usb ports and they are all set to enabled and I tried w/ and w/out usb legacy also.
Freaking driving me nuts all I wanted to do was keep some air between my two graphic cards and can't for the life of me figure out why my computer is not enabling the wiress usb adapters!@#$
Any help would be greatly appreciated. I really think its a USB driver issue of some kind..but I believe I'm all updated?! Windows Update/Asus website what else can I check?
Thanks in advance! Off to work.
netsh winsock reset
