I picked up two 512 MB sticks and flogged them on a VDIMM-modded P4C800-D. My sticks have the 2-2, 5-ns, -5B C Micron ICs, 0412 date.
They don't do much on an Abit board at 2.8 VDIMM: 240, 3-3-3-5 and trouble >280, 5:4. I put them on the P4C800-D where all I can use is 3.06-3.16-3.26 VDIMM and they take off.
Max out at 261, 1:1, 3-3-3-5 at 3.26 volts. Won't do 3-2-3-5. Sandra unbuffered is 3500 or so. At 5:4 they did 293, 5:4, 2.5-3-2-5 at 3.16 (more don't help). My CPU is crapping out here though. Sandra unbuffered is 3400.
I was also able to run 285, 5:4, 2.5-2-2-5 at 3.06 volts. I may be able to go higher. This seems as fast as 2-2-2-5.
At the settings above, I passed all my suite of 3D stress tests including PCMark2004. Only test the ram/CPU hiccupped a bit on was 3DMark2003. Mainly CPU1/2 test so don't know what's up as that is usually a CPU problem.
Yeah, unbuffered bandwidth is all in the 3100-3500 area, 3DMark scores look pretty good. I have a 120 mm fan blowing on the sticks. The ram has no heatspreaders and are made in China. The PCB has a real complex resistor design compared to the ADATA PC4000 stuff. My suspicion is the layout is more 5:4 friendly compared to other manufacturers.
There is still no substitute for BH-5 at 2-2-2-5 settings, but the ram really runs well on the Asus boards and is very versatile. It needs volts to satisfy the avid overclocker, but the VDIMM mod on the Asus boards is pretty easy. I got my sticks in Japan for a bit more than Newegg as I wanted to check the ICs, but $89 per 512 MB stick from Newegg is about as cheap as you can get for ram.
261, 1:1. 3-3-3-5 are ugly timings, but feels more like 2-3-3-5. This ram, abeit on a volt-modded board, fills the void in the 250-260, 1:1 arena, where BH-5 is problematic. You will get real nice benches on a 3.0C at 255 fsb, 3.84 gig .
