- Thread Starter
- #21
How in the world do you reach the "Extreme System" temps of 5-10c?
Is that with or without a chiller added? For my next upgrade to my PC (when my finances recover from building this one) I want to purchase the "Monsoon Hardline Pro Bending kit" and do a full custom loop with the acrylic glass tubing and the Monsoon hardline compression fittings. Still doing research of the radiator but there are some really cool looking reservoirs, I really fell in love with the "Mayhem a Aurora coolant" that stuff just looks awesome! As far as a pump I wasn't sure but I thought the monsoon MMRS series 2" looked pretty sweet, obviously I will have to do more research to ensure the performance matches it's good looks!
The only downside was when I priced it out I was at around 600-800$ so that's one pricey loop. The picture below shows the concept that I really like, I really prefer where the tubing is a single piece as long as possible. Not a fan of the loops I have seen that have fittings and connectors every 2-3 inches and look like a stack of pick up sticks!
So I kind of ran off topic for my original question, but how did you manage the 5-10c temps?!?!
And a random thought that popped in my head last night, I really wish they had small usb powered air conditioners (that could run without creating moisture of condensation) so in other words, a dehumidifier of sorts that puts out extremely cold air....
That would be a great tool to stick inside your pc case, then you could get your ambient temps down extremely low which would then seriously increase the performance of your cooling loop!
However, since I don't believe something like that exists it's just a cool idea to think about!
