Been considering updating my Phenom II X6 to a more modern Vishra x8 but with them being 125w to 220w I was also considering water cooling. But, my present system, the 120mm fan that blows across my CPU heat sink also blows air down across the chipset heat sinks of my MSI 990FXA-GD80 motherboard. With a water cooling setup I won't have that fan any more. Would I need to worry about the chipsets or would I need to some how jury rig in a fan into the side of the case? The case is relatively modern, a Fractial Design Define R5 (good case, but the motherboard and it don't get along due to the sunken motherboard tray and the front USB 3 connector. >.< ) but if I do get the water cooling setup the front two 140mm fans would be swapped out for the radiator and it's two 140mm (or 120mm) fans.
