- Oct 12, 2011
- Cypress, CA
Hello everyone,
I work with an LCD MFR, EIZO. EIZO has had gaming displays in Asia for quite some time and is doing very well. We are introducing our technology to America now.
The display is a 23" LED LCD. It has certain features that make it quite exciting for a gamer:
Power Gamma for Gaming
This feature produces images that are vibrant and rich in detail. Power Gamma has two settings - "Power 1" which sharpens midtones and "Power 2" which brings out subtle differences in the low tones for better clarity in dark areas.
Fast Response Time, Minimum Input Lag
An overdrive circuit is included to reduce gray-to-gray response time to 6 ms and ensure that moving images look clean and sharp with minimum ghosting. The input lag or the difference between the time a signal is input into the monitor and then shown on the screen is less than one frame. This is approximately 1/60th of a second, so gamers see the action as it happens and react immediately.
Smart Resolution
A new EIZO-developed feature called "Smart Resolution" analyzes both still and moving images for noise and blurring and then adjusts them to appear more clear and natural. This feature is "Smart" because it only adjusts the image in areas where it is needed. For example, in a web page with both video and text, Smart Resolution may detect that the text should be left as is but the video should be made sharper. In a photograph, Smart Resolution may detect that minimal adjustment to hair is necessary, but make skin appear smoother and more natural.
Would these features make you look differently at a display?
Thanks for your time guys!
Will
Smart Resolution
Will
