Hi, I did build a Ryzen system in Mars and after weeks passed, I did make a custom loop and put the system in a nice case Corsair 750D.
The problem I have is ALL the fan:
Radiators fans : 4x 120mm CoolerMaster MasterFan Pro Air Pressure, about 5 months old.
Problem 1 : Rattling noise, annoying, depend of the fan RPM. After time a was able to set it to a less annoying RPM. (they seam to all have that issue)
Problem 2 : The two fan on top of the case (on the 240mm rad) are configured for pull between the case frame and the radiator. It's no more of a "problem" as they never go to 100% anymore but when they do (if a change the fan parameters or if the CPU reach 80ºC [should be never]), then they seam to move down slightly more out of there normal position and the hit metal and make really loud clac clac clac. The two other fan (on two other 120mm rad) don't seam to have that issue yet.
Case fans : 3 x 140mm than came with the Corsair 750D, about 4 months old and of Corsair brand.
Problem : It's been like 4 month and one already began to fail (normal bearing wrowrowrowrowrowro sound).
So, I think I will change all the fan, My plan by making an abusive custom loop was to not hear my computer and to maintain more that 4Ghz of CPU OC + some GPU OC... But the Question is, What fan to choose now that they are making a fail party? My initial plan was to put all Corsair ML. But after getting one of my 3 corsair to also fail, I'm not sure if I want that.
Any recommendation for good fans? Air flow for Case and Air Pressure for the rads.
