- Feb 26, 2013
- Glasgow, Scotland, UK
- Thread Starter
- #21
You seem to know an awful lot about cooling. So I'm going to go with your suggestion of the HR-02. It's quieter, better, and only an extra £10, which I think is worth it. That also means I don't need to move my ram, and I can buy a second fan for it to increase cooling. Every C helps lol.
Right, as for fans. Are you suggesting the TY-147 for the HR-02?
For my case, I was just going to go with more of what it has built in, the NZXT fans, I want maximum cooling on this thing, and was thinking that keeping brand would be good. My only concern is noise, but the built in NZXT fans are quite quiet, can't hear a thing when any sort of music is playing.
Right now I have a spare:
140mm front.
200mm top.
200mm/230mm Side (Unsure if this will fit when HR-02 is installed)
(Case Dimensions 222 x 540 x 623mm
I was looking at buying 2x 200mm and 1x 140mm, all with blue leds. Those three would cost £42. Stupid expensive... Are they necessary?
I have a feeling the Side 200mm would do quite good, as it directly faces the motherboard and would help with cooling the GPU, CPU, etc. Unsure about the other two though.
Currently I have.
Rear Cooling fan 1 x 120mm
Side Cooling fan 2 x 120mm
Top Cooling fan 2 x 200mm
A link to see the specifications of my case.
http://www.novatech.co.uk/products/components/cases/cases/895562002742.html
Opinions?
140mm front.
200mm top.
Currently I have.
Opinions?
