- May 13, 2005
- West Chester, PA
Pretty sure my Alienware is Negative.
I just used common sense to figure that i have positive, becuase all my 120mm fans are the same, they move the same amount of air if they run at the same speed. Otherwise just add up the CFM of intakes and then the CFM of exhausts and compare them. And as for your 2nd question - air will leave\enter through any little gaps in the case, like vent holes ect. so your case wont explode.Revivalist said:
1. How do you check?
2. (Ok, I know this is a stupid one but . . . ) If you have constant positive pressure (more air goes in than comes out) then wouldn't the case eventually explode? . . . Or if you have constant negative pressure (more air comes out than goes in ) then wouldn't the case eventually implode? . . .
Ok, I go it. . .Vince1990uk said:And as for your 2nd question - air will leave\enter through any little gaps in the case, like vent holes ect. so your case wont explode.
Yes, basically air that is actively (e.g with a fan) being taken in or exhausted. And yes, your set-up looks positive to me, and you would include your side fan.Revivalist said:So not to be too technical, but what we really mean by "the overall air flow of the case" is more accurately, the total air flowing in from the front compared to the total air flowing out from the back. . . . Or would I still include my side panel fan pulling in air as well?
