- Dec 2, 2003
What should i get?
ViaAqua Water Pump Model 1300
http://www.drsfostersmith.com/produ...&Ntk=All&Ntx=mode+matchallpartial&Np=1&N=2004
it says it has to be submersed at all times, does it really? and does it work with the 1/2 tubing?
or the mag 3
http://www.thatpetplace.com/Product...es+Water+Pumps/T1/F78+0364+0110/Itemdy00.aspx
single heater core (for 120mm right?)
http://www.dangerden.com/mall/Radiators/heatercore.asp
or this radiator
http://www.frozencpu.com/cgi-bin/frozencpu/ex-rad-07.html
I dunno if i have room for the radiator and everything (i do for 80mm radiators but not 120) heres a pic of the inside of my pc
http://img45.imageshack.us/my.php?loc=img45&image=cablesafter.jpg
so since theres no room i could mount it on the outside of the case right?
should i use this?
http://www.swiftnets.com/products/MCB-120.asp#
$25
but wouldnt just any old shroud work?
http://www.svc.com/cw-mini-coolshroud-uvblue.html
id be mounting it onto an 80mm case fan slot so dunno if it would work. (btw wouldnt the case fan that the shroud/housing radiator goes over be useless since the fan is exhaust and its blocked by the housing and the 120mm fan and radiator?)
should i get this water block?
http://www.frozencpu.com/cgi-bin/frozencpu/ex-blc-90.html
reservoir
5.25 inch bay ones
http://www.frozencpu.com/cgi-bin/frozencpu/ex-res-36.html
or the round ones
http://www.xoxide.com/waterreservoir.html
or should i just get a t line? i dont really understand them, does the t line tube (part where you fill the water in) get connected to the pump or somethin?
or the mag 3
or this radiator
should i use this?
$25
reservoir
5.25 inch bay ones
or the round ones
