- Jan 31, 2002
- ON, Canada
Hey guys, I posted this over in general hardware but didn't have much luck so I thought I'd ask it here as it relates to my SMP system.
First off, some system background info:
MSI K7D Master-L
2 x Athlon XP1600+ (W/c)
2 x Elixir 256mb PC2100
AMD Radeon 8500LE 128mb
SB Audigy
IDE Controller (4 drives)
Anyway, for the past few days I've had this really weird problem. When I start up the computer, it will not post and there is a weird noise coming from inside, similar to a fan having trouble or the HDD LED just going to town. This noise is not a fan.
What I have to do is either reset or power off and back on the machine at least 10 times each time I want to start it, and the odd time it will actually post and log in.
I've checked and it's not any of the HD's, it's not the optical drive. The LEDs on the motherboard told me it was getting hung up on the RAM - so yesterday I played around with the RAM, sometimes it would work, sometimes not, so I don't think it's the RAM either. Memtest showed no RAM problems.
Everything was fine before this problem, the only thing i can think of was that i changed some mem timings in the BIOS, but I also changed them back, but the clicking continues.
The computer will either hang with R-R-R-R which according to the manual means the CPU is damaged or installed improperly. Whenever I boot and get the R-R-R-R - the hard drives don't spin up, does this mean it is the power supply and not my RAM?
Or it will hang at R-G-R-R which is the memory detection test - will hang if memory module damaged or not installed properly.
If I remove a stick of RAM, it sometimes hangs at G-G-R-R which is decompressing BIOS image to RAM for fast booting.
Once I get it to the G-G-R-R stage, it's a matter of hitting reset X times until it boots up.
I checked the PS with a multimeter and all voltages are fine.
Also, for the record, I am not overclocked in any way.
Changing the FSB jumper from 133 to 100 seems to sometimes help the system boot, but it is also hit and miss as in it will sometimes start and sometimes not, regardless of jumper setting.
Here are the readings from MBM5:
Case - 31C
CPU - 27
CPU - 27
Core 0 - 1.73V
Core 1 - 2.50V
+3.3 = 3.25
+5.0 = 4.87
+12.0 = 12.28
-12.0 = -12.27
-5.0 = -5.29
Also the computer, 3 times now, has randomly shut itself off, which makes me think it's going to die soon so I'd really like to get this problem figured out.
Thanks for reading and I hope you guys can help!
MSI K7D Master-L
SB Audigy
Case - 31C
CPU - 27
CPU - 27
Core 0 - 1.73V
Core 1 - 2.50V
+3.3 = 3.25
+5.0 = 4.87
+12.0 = 12.28
-12.0 = -12.27
-5.0 = -5.29
