- Jul 5, 2012
- Virginia
Okay, so if anyhone has read my prior post I have been worried about my GTX 550 ti running on a high quality 600 watt psu...It runs like a champ..So onto my complaining!!!
Why did I buy this stupid FX-8120? I have no clue. I only have a Hyper TX3 cooling it, but I figured I could atleast get a 4ghz OC with it. Although that def isn't happening. Anytime I raise the FSB the temps sky rocket. Right now I just have the CPU multi up. I know most say can OC this cpu with Water cooling but I am scared to death. It would be my first Water Cooling setup. I just want to have a closed looped for the CPU because my 2 GPU's never touch above 65c.
Also I have to keep my case side open or the RPM of my fans decrease dramatically. I will be purchsing a Water Cooling unit along with a new case. Maybe get a decent quality 750 watt psu just for safety. This will be purchased after the 1st of September. The Case I have now is a Full tower Antec something from like 3 years ago. It sucks for case airflow.
So I have my eyes set on the new HF 922 to cool my other components, but I would like to know what is a decent closed loop water cooling unit for my FX-8120..Cause right now I'm really close to sending it back because my Athlon II x3 455 can do Intel burn test faster than the Fx-8120 at stock settings and I can overclock my Athlon II x3 455 to 4ghz stable, 3.8 ghz stable if I unlock the 4th core with temps never reach 45c during full load. This fx-8120 jumps 10-12c in a split second during idle. I have seated the HSF 2 times already with the most optimized spreading method. I am using Ceramique 2.
I want to get a stable 24/7 4.5ghz clock. So with that in mind. Would the H80 be my best bet, or is there a cheaper solution. Also is that HAF 922 the way to go. With those 2 items I would like to spend around $200, not including aftermarket fans I will purchase myself.
Below is a screen shot of idle temps. As you can see my TIMPIN0 and 2 went up to 78c. Again. This is a split second temp reading and it goes back down to the normal temps. Also my 12v rail fluctuates alot..Is this normal?
[/IMG]
