You probably wont notice CL 17 unless you bench test. AMD is suppose to be coming out with a new memory update soon. Link: http://wccftech.com/amd-ryzen-memory-support-to-be-expanded-with-upcoming-microcode-update/
I feel like I should post back what I ended up with. After company not shipping me items, I was forced to refund and I had to order from another one where they have very limited options to pick from. Luckily enough, I purchased for 189€ HyperX Predator CL16 3200MHz (HX432C16PB3K2/16). Currently I am running it with XMP 2 on 2933 and I am waiting for a more stable bios to have it finally 3200, maybe I'll even overclock then to higher, I guess Frequency > CL17 would be worth?
Here is single sided Hynix IC
It's not about Samsung or other IC but memory build and its profile ( more like single sub timings and how BIOS can read them ).
Did you try at 3200 ? You may try higher VDIMM and DDR VTT voltages to make it work on Gigabyte board. On Samsungs it was required to run stable but I had no Hynix 3200+ kits to check it since I got ryzen. I had only one lower binned kit which couldn't pass 2800 on Intel and made exactly the same on ryzen. You can also try manual timings like 16-16-16 ( or 14-16-16 at higher voltage ).
I see that people are creating weird theories before they actually check all options. Other forums are flooded by stupid comments about memory for ryzen.
For me on Gigabyte B350 and ASUS X370 all single rank memory kits could run the same as on Intel or at 3200. All dual rank kits could make stable 2666 ( 2x8GB and 2x16GB ). I guess that new BIOS will improve max memory frequency.
All are saying that single rank Samsung B is the best for Ryzen ... just because there is almost no other single rank Samsung IC sold in 8GB modules. Hynix AFR/MFR is also single rank in 8GB modules so if manufacturer made profiles right then it will work on Ryzen.
In most cases difference won't be big but on Ryzen everything is linked to one bus so higher memory performance is affecting everything else. Depends on used software and additional hardware you may see higher performance gains while using higher memory frequency. On the other hand tighter timings are not helping much. The same frequency perform about the same regardless if memory runs at CL14 or CL16 while there are couple of FPS difference between 2666 and 3200. I think on TPU was larger memory test in games with these results.
So memory frequency counts when you see lower FPS but totally won't make any difference when you already have 60FPS+.
I hope we will see higher memory ratios with new AGESA. I'm actually surprised that there are no new BIOS releases with 1006 as it was out some time ago and for some boards we got 1004a instead of 1006.
In 1.0.0.6 update they added new ratios, so now possible to choose 3066 3333 3466 3600 3733 3866 and 4000. Also 1.0.0.6 update should start to hit consumers next week (for asus and asrock at least). I hope that with stable 1.0.0.6 BIOS on my taichi i'll get 3600 or 3733 with CL16 without bclk.I hope we will see higher memory ratios with new AGESA. I'm actually surprised that there are no new BIOS releases with 1006 as it was out some time ago and for some boards we got 1004a instead of 1006.
oh... u found some very crappy RAM, cos i got 3200 even on cheapest OEM sticks. And u have ch6 which is much better for OC.I am hoping my ram can hit 3200MHz. Stuck at 2133/2667
btw can some1 explain me how to tune ryzen for better power consumption? I kinda hate it already, when 65W TDP rated CPU without OC draining 120W under just 5-15% load... Need to fix their stupid turboboost, which is turn vcore to 1.4V from 4-5% CPU load. If i OC CPU i have less power consumption on low CPU load, but much more on idle Examples: no OC = 10W idle, 120W low load, about 140W full load. OC to 3.8 = 30W idle, 60W low load, 200W full load. When OCed vcore dont drop below 1.1V, when no OC its drop to 0.9V and at the same time while OCed below 4.0GHz it never hits 1.4V vcore (unlike none OC mode).
I have been using Dominator® Platinum Series 16GB (2 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit (CMD16GX4M2B3200C16). I can get upto 2667Mhz. I am planning on getting a second set of this ram to run them at 2400Mhz on all sticks. I am running this on a Ryzen 1700 with a ASUS CROSSHAIR VI HERO AM4 motherboard. I run at stock 2133Mhz by default at the moment so no issues here yet that I have notice.
Did u try agesa 1.0.0.6? On taichi i run my RAM 3600 without bclk.It run higher on Intel, but on Ryzen it dosen't I think I can hit around 288XMhz forgot what number but I don't think is stable at all.
I tried whatever bios is currently on asus crosshair vi hero am4 support site. No luck yet with it.Did u try agesa 1.0.0.6? On taichi i run my RAM 3600 without bclk.
