- Sep 27, 2003
I saw this a couple weeks ago.
I figured I'd share. I'm sure there are other reviews that show different, but this one showed the tightest timing at 305mhz to be PDP Patriot's XBL.
If you have other reviews please post them. I'm very interested to see who's best TCCD around here (don't go picking RAM that is insanely priced... obviously money buys the best stuff).
"PDP is also using the Brain Power PCB, however, it is a more recent revision, B6U815. Comparing the performance with the other Brain Power PCB it is clear that this revision takes the upper hand, both at tight and relaxed timings."
"These A-DATA made a very remarkable appearance, delivering speeds I did not see before when using 2 modules!"
According to this review PDP Patriot had the highest low latency frequency with 1 stick, but the A-DATA had the best with 2 sticks.
I'm just trying to figure out what the best TCCD bang for the buck is. I already have the PDP Patriot pc3200 XBL 2x512 kit.
