- Oct 14, 2007
Restored thread, deleted double post. Sorry for staff confusion!
just check in the bios that turbo core and all the green stuff is still off and that you have manually set the ht and cpu/nb speed.
other than that it's not a big issue.
Hey Oldie ..... I have been kinda following your thread but have just been too busy to really jump in. Your wobble as you call it is just your FSB fluctuating a bit not totally uncommon. Not something I see in my CHIV or CHIVz very often but once in a while. While I do have the Sbabertooth I just bought it and have had absolutely no time to play with it and cant really comment on it , I am sure that Johan when he pops in maybe able to shed more light on it than I can.
From what I have seen in your screen capture your OC is coming along nice .... well done. In the mean time if you wish to try a bit more CPU/NB volts a slight bump shouldn't hurt anything as you will probably be needing a bump soon if you are planning to OC your ram, just keep an eye on your temps. Keep in mind whenever you add voltage you will be adding some heat in your OC somewhere.
When it comes to your NB and HT frequencies for me I have not had to / not been able to get up over the 2400MHZ and have kept them in lock step while I know RGone and I believe CaddiDaddi have gone higher. Could just be that I have not used high enough CPU/NB volts ...... the last year I have been busy and not had the time to play as much as I would like. That doesn't look like it will change anytime soon either. I'm off now but I am sure RGone or Johan should soon be by.
As of my post in 264 about the situation of the Sabertooth sometimes not seeing the Ram speed etc. And a little fix to try to resolve it, but C--D i was not sure of my facts hence, i told Oldie to wait for you Guys!! Just edging my bets lol.
Well looks like Oldie is back on line now so i will sit on the side and let you guys deal with the Questions. AJ.
Nice work Oldie. I came in to check on things this morning and couldn't find your thread. But I see you've been put back now. Sorry I couldn't spend much time but it was Canada's birthday weekend so very very busy.
I see you're coming along quite nicely. Your almost at your max temps though, so play time will soon be over.
I wouldnt worry about ram speed personally. There are VERY little gains past 1600MHz in the first place.
If you're going to OC the ram you have to treat it just like the CPU and bump the volyage while still maintaining the same timings. Did you notice the memory performance was the same at 4.7 as it was at 4.8 after you dropped the NB frequency. Your NB is the internal memory controller on the CPU so theoretically the faster it is the better the memory can perform but there's always a limit. I have managed to get my memory up to the low 2500's but had to loosen the timings quite a bit.
Got yapping and forgot bump your memory up to 1.55 and give it a shot at 1900 also to keep the NB stable you'll probably need to go up on the voltage for it as well
