- Jun 20, 2013
- The Netherlands
- Thread Starter
- #281
No that's a slight over volt. But just like any overclocking the risk is totally yours if you choose to run outside factory specifications. That being said overvolting will help with some ram and not others it all depends on the chips in the ram itself. G.Skill is usually pretty good about a little extra volts. Like I said earlier The CPU_NB voltage will need to be raised as well since the faster the ram goes the harder the controller works as well.
need an answer for this error
I did bump Vcore twice at 1.452 bios and bump cpu/nb at 1,25162, and leave the DramV at 1,5 and cpu at 4,94Ghz.
Do i need much more Vcore for this overclock?
That all depends on your chip. You've already went way past what I could at 1.45v, you obviously have a much better chip than i do.
That being said once I got to that point I needed a whole lot of V_core to get close to 5.0G when I say a whole lot I mean It. Check this thread, It's not for the squeamish
How much you need is up to the chip and there's only one way to find out.
So Johan while Oldie is testing what would be a good every day OC for this set up?? AJ.
P.S. The TEMPIN2 Johan i take that is a broken sensor or false reading yes!
I have no doubt that 4.9 is going to take more power than you'll be happy with Oldie. And yes if anything on your board was that hot you'd hear some popping or something.
4.6 is a good range for everyday computing temps are great and voltage is low, we'll play around with the ram and NB/HT if you want Oldie. Did you notice like i said earlier the drop in maxmem when you dropped the NB?
Just the language barrier. I meant performance dropped when you lowered the NB frequency.
goodnight m8Yeah Oldie good night time to go here, 4am start best regards. AJ.
Hello Guys
Just wanne now or these setting allowed for everyday use.
I know the temps are ok but i wanne know or the Vcore is allright for 24H
Oldie
benckmarks
there is something that i cant understand.
When i increase the Dram V i get an higher performance in CineBench, but lower performance in MaxxMem.
Do i need better Ram performance or do i need better OpenGl and Cpu score?
Omg i make a big mistake, more Dram V less performance in Open-GL more performance Memory-copy but lower performance Memory- read - write
dram V 1.51875V
edit: i hope you can understand what i mean.
Hello Guys
Oldie
Edit: bussy with tweaking
benckmarks
dram V 1.51875V
Yes they're fine!
Benchmarks will vary from run to run. Run it twice and you'll get a different result.
Yes the NB plays an important role in the FX chips will improve video and CPU scores.
OOps not sure how I managed the double post. You're doing fine Oldie
