- Aug 16, 2009
When When say push hard I am talking about running my FX8370 full on all 8 cores @ 5.1GHZ for hours on end or someone lik Johan or Mandrake4565 trying to squeeze that last few MHZ for benching. You can add anyone that want or has Z need to run their FX8XXX at 4.7GHZ+ stable to that definition. For someone like you who may try an OC like you stated 4.2GHZ ish to maybe 4.5gHZ or stock there are boards that can run them just fine. Keep in mind there are just a couple boards outside of our recommended boards that can run it up to 4.5GHz.
The problem you will find with your board if you should find the want or need to go beyond that is where you will need a better board and better cooling. Granted the newer chips don't seem to need as much VCore to OC but the heat you have to deal with is still there.
If my rig died today and I had to put something together on a budget I can guarantee you I would not even think of anything less then a 8 + 2 motherboard.
