I usually hang out on the cooling forums, but of late I became much more interested in the next CPU upgrade from Intel. Which will be Haswell and IB-e. I run a x79 platform on a 3930k, running at 5.0ghz and some pretty high voltage; reasons for that is work related, my job and my career revolves around number crunching, and at times I got 'terabytes' worth of data to handle. I have already started to use my GTX680 SLI into openCL solutions, which helps alot.
now, here are the stats of IB-e: (credit to wikipedia)
question is, is it worth the upgrade?
my 3930k runs at 3.2Ghz stock standard. I run at 5.0Ghz, which is a 56.25% OC. (thanks intel!)
and 4930k runs at 3.4Ghz stock standard. 6.25% increase on stock.. given OC will be similar, I will assume I can go 150% ... meaning.. 5.1Ghz...
the largest possible benefit is really just with the increase in quad RAM capabilities, but I am already using 2400Mhz RAM.. so I 'suspect' the only improvement I will be seeing will be on the CPU freq.
anyone here sees any good reason to upgrade when it comes?
or should I be targetting the 4960X at least for a worthy upgrade?
