- Nov 1, 2009
- Austin, TX
You know that the higher end x79 boards also have south bridges that add more sata 3 connectors...
true. Usually the other controllers have 4 ports and can do that. Depends on the controller.It would be awful hard to set up a RAID 10 with two SATA-6 ports.
It's gonna be a long wait...sell your rig and go dual 780and with ivy-e and grab gpu and cpu pots and ln2
win-win
in my part of the world, parts don't sell as well.
I think we talked about degradation is another post and it should take a min of 5+ years to show ANY signs of degradation
but can seem to find the thread
My e6550 showed degradation after two years at 3.2 ghz. Needed more voltage. I just got a 124 bsod on my 2600k at 4.8ghz after two years. Needs more voltage. They take a lot less than five years to show degradation.
I'm also patiently awaiting ivy-e or haswell-e launch. Partially for the pcie3 and partially for an updated memory controller. I have a love of ram drives and my ram unfortunately has to be run below spec (2133 instead of 2400) to maintain my 4.7Ghz overclock. I realize that the difference is probably near nil but it still bothers me. I'm also curious if the motherboard companies will release a refresh of their x79 motherboards if they do in fact launch ivy-e. If they end up skipping to haswell-e then there will for sure be a motherboard refresh because it would be on a different chipset. Either way I await patiently for my next epic build...
