kr7777 Member Joined Dec 13, 2013 Location INDIA Feb 1, 2014 #1 for the last few days my Windows 7 Aero goes to basic all by itself for say 1-2 minutes dont know what to do.
Luke1978 Member Joined Dec 5, 2013 Location Maine Feb 1, 2014 #2 Is your system overclocked at all? An unstable overclock can cause the svchost.exe associated with Aero to timeout. What are your system specs?
OP kr7777 Member Joined Dec 13, 2013 Location INDIA Feb 2, 2014 Thread Starter #3 yes.cpu is oced to 3.8ghz. but it was stable with prime 95 for 2 hrs
EarthDog Gulper Nozzle Co-Owner Joined Dec 15, 2008 Location Buckeyes! Feb 2, 2014 #4 2 hours...? That should be fine but not always. Most people will say to run it four hours, but to each their own... Anyway, have you tried reinstalling and/or updating your GPU drivers since Aero is run with GPU acceleration?
P pcgamer4life Member Joined Dec 30, 2004 Feb 2, 2014 #5 Revert to stock clocks and see if the issue persists.
redduc900 Inactive Moderator Joined Dec 17, 2000 Location Portland, OR Feb 2, 2014 #6 ... and list your system spec's like Luke asked you to. Edit: I see you listed your system spec's in another thread you started regarding overclocking your GPU, so I'll just copy / paste them here: phenom x6 1100t oced to 3.8ghz. seasonic s12II 520watt bronze psu. 8gb zion ram 1333mhz. zetway ha12 motherboard. driver 332.21. using msi afterburner 2.3.1.
ShrimpBrime ~MadHatDeLidder~ Joined Apr 19, 2012 Feb 2, 2014 #7 type aero in the search bar. Then tell aero to look for problems. It may auto correct it'self.
