I have a file server...
Athlon x2 4200 in a Skt 939 DFI RDX200
4 Sata HDDs (7.5Tb for storage)
1 IDE HDD (80Gb for OS)
2 Sata dvd drives
Windows 7 x86
For those unfamiliar with it, the board has 8 sata ports total. I wanted to add a fifth Sata hdd and reinstall the OS on it, removing the IDE drive.
So I unplugged all of the drives except the new Sata HDD and one of the Sata dvd drives and cleared CMOS.
I then started the Windows install. It got to the point where you typically partition the disc, but instead of that, I got an error stating my CDROM/DVD drivers were not present and setup could not continue until I had inserted a disc containing the driver.
Two things right off the bat. First, the dvd drive was obviously recognized and readable since setup had already commenced. Second, wouldn't a chicken/egg scenario arise with me inserting a driver CD in order to fix a driver issue with the CD device?
I tried using different windows discs, the motherboard driver disc, a Windows 7 x64 disc... Setup couldn't find the appropriate driver on any of them.
I cleared CMOS again and restarted the process. Same problem.
I tried different SATA ports. Same problem.
I tried several different settings in the PCI Devices menu in BIOS.
Enabled Sata Ports 1&2.
Onboard Sata Type = IDE
Onboard Sata Type = RAID
Googling led me to believe Onboard Sata Type = IDE would fix the issue, but I couldn't even get past the mobo splash screen with that setting and my two sata devices plugged in.
Does anyone know what the problem is here? It seems insane that I'm having issues installing an OS when I've reduced the problem to just one Sata disc drive and one Sata HDD.
Thanks in advance
2 Sata dvd drives
Windows 7 x86
Thanks in advance
