- Feb 9, 2002
- Pensacola, FL
I agree with computerpro3. Your problem is your case temp. There is a direct relationship with this temp and CPU/Diode temps. If your case temp goes down, so will the others. Somehow your case is trapping or not ventilating enough to exhaust the heat. What kind of case do you have? Make sure you have an inlet and outlet for your case. Also make sure you have enough fans to help direct the air inside your case. Finally, make sure your case is not sitting or near a heater...lol. Good luck!
