- Sep 25, 2003
- Mesa, AZ
- Thread Starter
- #81
bfedorov11 said:i didnt want to start a new thread so I thought I would just throw a question or two in about case airflow...
a) when trying to establish proper air flow, more intake than exhaust, do you consider the psu too? I have a Fortron FSP530-60GNA and it has 2 fans. I just have the stock kingwin case fans, 2 in and 1 out, rated at 32.4 cfm. Not sure of the psu fan specs.
I was gonna add another exhaust at the top of the case, so would i need another intake fan? or should i just not do this?
b) If I hookup mult fans to one power source on a fan contoller will they all still run @ 12v?
thanks
You should have no problem running most fans @ their full voltage on a controller. I just bought a Vantec Nexus about a month ago. It supports up to 18w per channel w/ 4 channels. Most any fan controller out right now should be able to do that. Your average 30-something CFM 80mm case fan only runs at about 7w. All your fans on the same power source should run fine, provided you've got a powerful enough PSU. In this case, a decent 350w PSU ought to be more than sufficient. I think you've got plenty of wattage in that Fortron that you mentioned.
