Just wanna share wif you my experience with this temperature issues:
I was using the SP-94 with 90mm Thermaltake fan (Model TT 9025A-2B) which put out 56 CFM at 2800 rpm with 35 dBA sound level. I believe this fan is OEM from Panaflo.
Casing has a total of: 8 X 80mm & 2 X 90mm case fans.
Temperature reading (via Fan Speed & MBM5) was:
At full load (2 X Prime 95): 58C - 59C
Case/System Temp: 33C
Room Temperature: 24.5C
To further improve the temperature, I changed the HSF to 80mm ThermalTake SF II. I manage to "slot" in the temperature probe in between the heat pipe and the based of the heat sink. The SF2 was running in "auto" mode which it will regulate the rpm based on the temperature of the heatr sink.
At full load (2 X Prime 95) - aircon room
CPU: 53C - 54C
Case/System Temp: 31C-32C
Room Temperature: 25C
Fan Speed: 3800 rpm to 4100 rpm
At full load (2 X Prime 95) - w/o aircon
CPU: 55C - 56C
Case/System Temp: 36C - 37C
Room Temperature: 29.8C
Fan Speed: 4200 rpm to 4500 rpm
I have another external temperature probe attached on the base of SP94 which read 42C to 44 C at maximun loading.
Idle - aircon room
CPU: 38C - 39C
Case/System Temp: 30C
Fan Speed: 1600 rpm to 2100 rpm
I can't hear any noise coming from SF2 for speed below 3000 rpm.
IMHO, this SF2 fit perfectly into my system. When surfing the net and doing some microsoft office works etc., I can't hear any fan noise. When playing games, I can't hear any fan noise either because the game music and special sound effect are a lot louder than the fan noise. Oh yeah, I could hear the fan noise if running P95, but thank goodness I don't run this software every day for it's scientific mathematical discovery
YellowDart said:
Thanks for linky!
I've read the review from bleedin edge before. There's a few ppl in their forums w/ my board, just because that Promethius guy gave it a good review.
As for the fans, how do those Thermaltake Smartfan II's do. I noticed they are capable of around 4800 rpm pushing 75 cfm. The 80mm Tornados are only doing just over that @ 84 cfm. I think they're rated faster than the Panaflo's. Those Tt's are the right dimentions that I wouldn't have to do any more modding to get them to fit my case too... I could prolly run to Fry's and pick a couple up next week. Let me know what you all think!
HAPPY TURKEY DAY!!!
