Dreamer3381
- Oct 21, 2014
Brand new system.
Corsair 900d
Rampage V
5930k
H100i cooler
AX1200i
16bg corsair Dominator Platinum 2800
2x Samsung Evo 256 Raid0
Win 7 ultimate fresh install
Bios update
2x 6950 GPU
On stock settings it will boot to windows and stress test on all platforms passes fine. However, any change to the multiplier, vcore, dram frequency, results in Blue screen of death after windows logo on boot up. I have been tuning and trying everything for 20 hours now, nothing works. I finally went Into the AIsuite and did the 5 way optimization and chose the 4.4ghz CPU setting and let it reboot and windows loads and no issues. Checked the CPU-Z and it is at 1.31 volts and 4.4ghz. I tested all stress tests and it remains stable at 4.4 and never exceeding greater then 69 degrees. Okay so then I rebooted and went into the bios and saw that the tuning used the XMP 3000 setting and I didn't change anything, just left without saving and no changes and again.. BSOD at windows logo. Never changing anything it doesn't makes sense. I am forced to go back to stock settings and retune and if I reboot and never enter the bios it will load and boot at and remain at 4.4 stable. Changing anything or even going into the bios has the same effect, windows won't load. I am not seeing any high temps, bad voltages, nothing. I am preplexed. Strange note upon BSOD, my Intel raid controler seems to vanish and it boots right to bios and after doing a hard reset it is fine again but still the same results on anything but stock settings or 4.4 tune and left alone.
Could my CPU be bad?
Memory bad?
Motherboard bad?
I need major help please. Oh and my BSOD error is the common Machine Exception.
Corsair 900d
Rampage V
5930k
H100i cooler
AX1200i
Bios update
2x 6950 GPU
Memory bad?
Motherboard bad?
