- Jan 3, 2004
I think the xp120 is great and at the same noise level setup probably outperforms the xp90. It cools my hammer at 1.75 volts- and it sure is kicking out tons of heat. I've never seen a heatsink throw so much heat all over the place its like a heater.
I read about it lowering the system temps too... I think that really depends, if the xp120 cools your cpu so well that it allows you to OC it very high it starts to kick a ton of heat around the case. Plus I have a geforce 6800 which puts out alot of heat so, my system temp is pretty high.
