- May 16, 2012
win 7 has 2 model x86(32bit) & x64(64bit)
advantage
+Sometime win 7 capables to resolve the troubleshooting by using their fix tool (hooray)
+You can upgrade memory more than 4 gb
+Better performance than xp
+/-Better sistem repair, but sometimes it can't work well
disadvantage
- Some device maybe difficult to get driver instalation or maybe the driver doesn't exist (i have canoscan 5000f & i can't found anysite related to my device's driver sob)
- If you want to use printer on win 7 & you want to share it with xp, formerly you have to install the device driver on xp
- Not every 32 bit application can be used in 64 bit
- Some printer Hp has conflict with microsoft office
*Win 7 has difference way to install network application
*Destop dispaly Aerocool is better than xp but prefer to Lion
*Use more than 1 Operating System to fix the problem
example : Linux can't be infected with win 7 virus, so you can eliminate some virus by using Linux (Ubuntu, Redhat, ....)
Maybe those just a little info to be considerated
advantage
disadvantage
