A very easy case mod – Vash
First, kudos to my older brother Mike for showing me this cool add-on. Next, supplies you will need:
- Scissors
- Plumber’s Wrap (Can be found at Home Depot or Lowes)
- Screws
- Screwdriver
Now, start by cutting four short strips and two long strips of the Plumber’s Wrap. Cut desired length depending on how many drives you want to add. In this article, we added two drives, so five holes on the two short strips and seven holes on the long strip. Add two more holes to the length to accommodate another drive, and so on.
Now we screw down the strips to the old 3 ½ bays and to the new drives. It should now look similar to these:
Now just simply put the old 3½ bay back into your case and connect everything and you are ready to go. Finished product:
