- Mar 1, 2004
- Poland, do you know where it is? :)
hi!
i've got a problem with checking the speed of my PCI and AGP bus.
At the begining i had C2,2 (22*100) GHz no o/c.
Sandra 2004 showed:
AGP Bus
Speed 4x 66MHz (264MHz data rate)
Multiplier 1/2x
PCI
Multiplier 1/3x
When i did o/c (22*133) to 2,95 GHz my Sandra showed:
PCI Bus(es) on Hub 1
Version : 2.20
Number of Bridges : 2
PCI Bus 0 : PCI (1x PCIClk)
PCI Bus 2 : PCI (1x PCIClk)
and
AGP Bus(es) on Hub 1
Version : 2.00
Speed : 4x
Multiplier : 1/2x
My mobo is Gigabyte 8IE800 and in BIOS i can set to keep 33/66 for PCI and AGP. I did so!
But it doesn't make any sense when looking at the Sandra :/
Does anyone know any other sw to check PCI and AGP frequency or multilpier?
It should be 33 and 66 but it is not I GUESS...
What's more my EasyTuning 4 utility from Gigabyte shows when running:
the old ver:
44 and 88 with the option to change to asynchoronous 33 and 66
the new ver:
33 and 66 and the asyn. set with the option to 44/88.
I am concerned about my disk controller and the PCI freq...
My pc does not reset by itself neither it hangs up...
I did some normal work with it /word, excel /
and also some 3dMark test. it worked ok...
sorry for my BAD English just look at the country i am from
HELP ME
Sandra 2004 showed:
AGP Bus
Multiplier 1/2x
PCI
Multiplier 1/3x
Version : 2.20
and
Version : 2.00
Speed : 4x
Multiplier : 1/2x
the old ver:
the new ver:
HELP ME
