- Oct 18, 2004
- Seattle, WA
Today I got two nice 92mm Sensflow fans in the mail (FFC0912DE), apparently they were pulled from some Dell servers. Here's one of them:
When I bought them I was told I would have to rewire the fans, which is fine, I'm good at soldering and all that.
Coming out of the fan there are four cables; yellow, red, black, and green. I assume yellow, red, and black are the usual +12V, +5V, and Ground, and maybe green is a sensor? I've heard about Dell using non-proprietary hardware designs so I just wanted to see if anybody was 100% on these.
The pin connection from the fan is six pin (3x2), with four wires being the ones I already stated, and an additional two wires (blue, orange) going to what looks like an LED mounted on the blue plastic fan shield.
If things are as I guessed, I'm just going to connect the +12V and Ground, and cut off everything but the yellow and black wire.
By the way, this fan states that it runs at 1.5A! Definitely putting a resistor or two in series with this. If 70-Ohm isn't enough and the fan is still loud, I'll probably trying using the +5V (red) cable as my new Ground, creating a +7V difference in the fan.
If nobody knows for sure I'm gonna run +12V through the yellow and black wires tomorrow to see if it works, hopefully I guess correctly and don't kill it lol.
