Ha! I don't even want to overclock my system! I wasn't sure if I should put this in the cooling forum or here. I'm curious about the temps other folks are getting with AMD 1090T and Corsair H50, that's why I went AMD specific.
Every 6 months, it's a new hobby for me! I'm just trying to get my temps as low as possible. After getting the H50 installed and bouncing about the internet, I soon discovered that blowing more air through the H50 is one key to lower temps.
So my idle cpu temp, at first, was about 28C and Prime 95 full load max temp was about 45.5C. My board temp was about 33C.
After some fiddling and diddling, I discovered that my case air flow left something to be desired. I switched my lone 12cm case fan from back exhaust to Front Intake and dropped the mainboard temp to 25C and cpu to full-load 44C.
I had to mount the H50 in my 3 vacant 5.25" drive bays and it's sucking air through the breatheable drive bay covers. This was because my ASUS 890GX mobo has a high-rise cpu power conn which was totally blocked when I initially mounted the Rad/Fan to the rear of the case.
Anyhow, I discovered that blowing air up the motherboard and, presumably across the cpu socket and under the H50 cold-plate/pump quickly knocked about 5 degrees off my cpu temp. Doing this, however required holding the fan by hand. No side panel mounting position offered the same reward.
I plan to do all kinds of experiments with air-horns, ducts, air-straighteners, shrouds, higher power fans etc in the near future, as soon as I get the supplies.
So if anybody has any recommendations or has achieved lower temps on a similar set-up, let me know. I can't do the 120mm x 38mm screaming Delta fan thing though I'll update this thread in the upcoming weeks with whatever I discover on my own.
